Repair ideas to an acrylic neck template? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=53600 |
Author: | LaurieW [ Fri Oct 16, 2020 2:00 pm ] |
Post subject: | Repair ideas to an acrylic neck template? |
My router took a few nibbles out of my mortise and tenon templates. These are the clear ones that StewMac sells. I was thinking fill with ca and file smooth, any other ideas for a repair? I’d really like to save it instead of replacing it. Thanks, |
Author: | Clay S. [ Fri Oct 16, 2020 2:07 pm ] |
Post subject: | Re: Repair ideas to an acrylic neck template? |
You could solvent weld new pieces of acrylic into the divots with acetone. |
Author: | meddlingfool [ Fri Oct 16, 2020 3:53 pm ] |
Yeah I always used to just drop fill with CA and file smooth.., |
Author: | LaurieW [ Fri Oct 16, 2020 9:30 pm ] |
Thanks guys, I’ll give one or both of these a try. |
Author: | Terence Kennedy [ Sat Oct 17, 2020 8:14 am ] |
I drilled some small holes in the damaged edge as anchoring points and used epoxy putty once. That was five or six years ago and it is holding. |
Author: | pkdz [ Sat Oct 17, 2020 11:52 am ] |
I have spliced in a tight fitting piece of plexi and used CA glue with success Paul |
Author: | Pmaj7 [ Sat Oct 17, 2020 11:55 pm ] |
Epoxy Pat |
